Hello,
Somehow, I deleted the Settings (Gear) button from the side bar by mistake and I can't find how to restore it. Can someone point me in the right direction? I really appreciate it!
Thanks,
Rob
Hi Robs iPad No worries.
Right click the toolstrip where the icon used to be and look for "Add/Remove Buttons" to bring it back. If that doesn't work, try Window > Toolbars > Reset to restore the default layout.
Last resort: Revu > Preferences > Admin > Reset (back up settings first) that'll bring everything back to default, gear included, if you still facing issue please inform me, thank you
THANK YOU!!
Rob,
The easiest way to get this back is to click the WINDOW drop down across the top, hover over the PANELS line, and then select the properties line.
[EDIT] Deleted duplicate screenshot
For us visual type folks…
