As you can see the label is showing in the Properties, but down below in the Markup list it is blank.
It was definitely there prior to the update, so I am hoping that it is just a quick fix.
Hey Cram C your data's fine it's just not rendering in the list.
Try toggling the Label column off or on (Markups List > Columns), or reopening the file usually forces it to refresh.If it persists, log it with Support since it's likely tied to the same 21.10 display bugs as the tool chest jumping issue, thank you
Hey @Cram C. The "Shelving - Laminate" is actually a comment for this markup, and would appear in the comment column. If you'd like to input a label, try using a measurement tool (perimeter, area) and input your desired label in the label field. Alternatively, use custom columns as I see you are doing with the Division field. What are you looking to produce with these markups? If it is a takeoff, please let me know and I'd be happy to assist further with your process.
We are looking to migrate our takeoff from Procore to Bluebeam and need some advice on Document management and exporting data to Excel.
FYI @Doug McLean & @Troy DeGroot did a two part webinar that's on the Uchapter2 YouTube channel that you might find helpful.
Part 01 - Bluebeam + Excel Power Query
Part 02 - Bluebeam + Excel Power Query
It may or may not help in your particular use case but great content none the less.
Thanks for the tag and link to our videos. My friend @Doug McLean is an amazing resource. I'm honored to have him do these presentations.
Yes Thank you.
Exporting to Excel is pretty easy, its what you do with it when you have it in Excel. That's where it gets fun. Both myself and @Vince French have workflows that utilize Power Query that will transform your data quickly and is easily repeated.
