Tool: Dark Mode 🌙 For all the night-shift engineers out there… this one’s for you. 😎 Working on Bluebeam late at night ❓ Switch to Dark Mode and give your eyes a break. Small setting. Better night workflow. 🌙 Night-shift engineers are you using Dark Mode❓Comment 💙
What would help others that may not know is HOW TO do the tip you are suggesting.
Sure, i will share the work flow of the Tips, real scenarios also, Thanks for your great comment
agreeed. separate note: This community web page could use a dark mode…
Josh,
There are many but I use the Chrome Dark Reader extension to blackout all website… well most of them, including this forum :)
Dhanush,
I flip between dark and light mode (ctrl+3) multiple times a day depending on the color and weights of the line work in the drawings. Sometimes dark mode will make thin or pale lines nearly impossible to see so I like to double check.
alright, thanks for sharing your live scenario experience Sim
