If i add measurement, it should automatically add ceiling height and give me the volume. i want that to be appear in the comments coloumn as well. how to do that?
Thanks
Gary
Hi Gary, Yes, this should be possible in Bluebeam using a custom measurement setup and a formula. You can have the measurement calculate the volume based on the measured area and a predefined ceiling height, then display the calculated volume in the Markups List. We can also configure the Comments/Subject field to show the volume automatically. The main thing is setting up the custom columns and formula correctly so the calculation updates whenever the measurement changes. Thanks!
if you need sample video for how to do Column Customisation , please check below, i have uploaded that.
Still have any doubts, please ask
