Hey Guys I used to waste so much time clicking through menus in Bluebeam... until I found this.
I'm sharing one feature I wish I had customized much earlier: Keyboard Shortcut Customization.
How to set it up:
- Go to Revu > Keyboard Shortcuts.
- Find the command or tool you use often.
- Click the shortcut field and press your preferred key combination.
- Save your changes and start using your custom shortcuts.
It only takes a couple of minutes to set up, but it can save you hours over time.
Have you customized your Bluebeam shortcuts yet, or are you still using the defaults❓
