First Time User.
All of these contract documents display fine in other viewers, but in BlueBeam, the drawn borders come apart and the right hand side has lines missing or skewed. Whats the fix?
Hi gvargo, Welcome! That usually points to a PDF rendering issue rather than a problem with the actual file. I'd first try going to Revu Preferences → Advanced and toggle the Hardware Rendering option (disable it if it's on, or enable it if it's off), then restart Revu. Also make sure you're on the latest Revu version. If it still happens, try opening the PDF in another Bluebeam version or ask the sender to regenerate the PDF, as some CAD exports can cause display artifacts.
Changing hardware rendering to software rendering, resolved it. Thank you.
great welcome always
