Build connections with Bluebeamers around the world, discover whatβs new, and make your voice heard.
Bluebeam users, What's one Bluebeam trick or hidden feature that most people don't know, but you use all the time? Let's help each other discover some hidden gems. π
CTRL+SHIFT+V = Paste in place is one of my favorite gems.
Chasing a riser up a building? Simply place a markup on it, copy it, go to the next floor you need to locate it and hit CTRL+SHIFT+V. It works off page coordinates so the drawings must align, but it beats pulling measurements off gridlines (assuming we have gridlines) !
Good sharing
I use Tools β> Form β> Text Boxs to create quick calculation template that require a graphic. It is Excel work but you get other tools to do markup, e.g. arrows, C-stud section, etc.
Good sharings
Most folks overlook that text boxes can have different shape outlines:
good sharing
This only works for Text and not pictures and only works of the pdf can recognize text.
Sometimes a set of plans has the wrong information on it and you need to change the text in a few places (think wrong address, misspelled name, wrong code called out, wrong detail called out, etc.).
If you make a mistake it is easy to go back with Ctrl-Z before you hit save.
If you do save and find the information you changed is bad up the road, just do the Search again.
wow noted
