when entering text in bluebeam max markup list, why doesn't it auto save and create a suggested list as you type like it did with core?In Bluebeam Revu, the Max edition differs from Core by focusing on advanced structural workflows. If your text fields and Markups list aren't auto-completing or suggesting past terms, it is usually because the feature is toggled off in settings or your workflow bypasses standard PDF logic. [1, 2]1. Toggle On Auto-CompleteThe Auto-Complete feature might be disabled in your General Preferences. [, 2]
- Go to Revu > Preferences (or press
Ctrl+K). - Under the General section, select the Spelling tab.
- Ensure that the Enable Auto-Complete checkbox is ticked. [1, 2]
2. Manage and Populate Your Word BankIf Auto-Complete is on but certain terms aren't suggesting, the dictionary for that specific field might be empty. Bluebeam tracks history differently per field category (e.g., Subjects, Authors, or Custom Columns). [1, 2, 3, 4, 5]
- Click the Manage button in the same Spelling window.
- Select the specific category (like Author or Subject) from the dropdown list to review, edit, or delete past entries. [1, 3, 4, 5]
3. Note on Bluebeam Studio SessionsIf you are working inside a shared Bluebeam Studio Session, Auto-Complete and instant markups list caching behave differently. Depending on your access level, the server may require you to save the PDF locally for the Markup list entries to be cached and suggested for future use. [1, 2]Would you like me to help you export and import an Auto-Complete list from a previous version, or are you having trouble with Custom Columns specifically?
11 sites
Show allYou said: enable auto-complete is checked. it only save some it's so weirdBecause the feature is checked but only working selectively, your text isn't saving for one of three hidden mechanics in Bluebeam. [1]1. Case Sensitivity and Hidden CharactersBluebeam stores Auto-Complete entries with strict string rules. If you type "Concrete" and then later type "concrete" or "Concrete ", Bluebeam may view them as conflicting or redundant. It will often stop auto-saving new variations if a highly similar entry already exists in the dictionary. [1, 2, 3]
- The Fix: Go to
Revu > Preferences > General > Spelling > Manage. Drop down to the specific column category (e.g., Subject, Label). Look for near-duplicates or entries with accidental trailing spaces, and clear them out. [1, 2, 3, 4, 5]
2. The 10-Item Storage Bug (Recent Cloud/Subscription Update)If you recently migrated to the Max subscription edition, a known bug tied to recent updates caps the dynamic Auto-Complete memory at exactly 10 items for actively typed data. Once you type an 11th distinct word, the system refuses to log it or drops an older one from the cache. [1, 2]
- The Fix: You can bypass this dynamic restriction by manually forcing your text list into the system dictionary. Go back to your Spelling > Manage screen, manually click the Add (+) button, and type your essential keywords directly into the category block. Manually added entries are locked in and bypass the dynamic limit. [1, 2, 3]
3. Subject-Locked Custom ColumnsIf you are typing text into a Custom Column, the auto-fill suggestions are entirely dictated by the markup’s Subject. If you type a specific text value into a column while your markup is assigned to the "Electrical" subject, Bluebeam will never suggest that word if your active markup subject is changed to "Mechanical". [1]
- The Fix: Ensure the markup you are actively editing shares the exact same "Subject" line in the Markups List as the markups where the text originally saved successfully. [1]
Are the words that fail to save happening in a standard field like Subject/Label, or are they happening inside a Custom Column you created? Knowing this will help narrow down the exact dictionary path to fix. [1, 2]
9 sites
Show allYou said: custom columnsAh, that narrows it down perfectly! Custom Columns behave very differently from standard fields like "Subject" or "Label" in Bluebeam Revu. [1, 2]If your Custom Column text isn't consistently auto-saving or suggesting as you type, it is because of one of the following distinct behaviors:1. The Column Type is Set to "Text" (No Auto-Complete)If your custom column was created as a Text type, Bluebeam’s global Auto-Complete engine intentionally ignores it. Unlike Core, the newer Max backend does not track typed history for raw text custom columns to prevent the data dictionary from bloating. [1, 2]
- The Fix: You need to change the column type from Text to Choice.
- Go to Markups List > Columns > Manage Columns.
- Select your column, click Modify, and change the type to Choice.
- Add your standard terms to the list.
- Crucial Step: While in that menu, click Format and check the box for "Allow Custom Text". This allows you to still type anything you want on the fly, but it gives you a functioning dropdown/suggested list. [1, 2, 4]
2. The Text Options are Subject-LockedWhen adding suggestions to a Custom Column, there is a hidden Subject property tied to each word. [1, 2]
- If you or a teammate associated a specific typed phrase with a markup that had the subject "Flooring", Bluebeam will hide that suggestion completely if your active markup is set to "Electrical". [1]
- The Fix: To make a typed word suggest itself globally for all markups, go back to Manage Columns, edit the Choice list items, and leave the Subject field completely blank. [1]
3. The Data is Locked to the PDF, Not Your ProfileCustom column structures and their saved typing choices live inside the specific PDF file by default, not your global Bluebeam program. If it works perfectly on one drawing but "forgets" your text on the next one, the column hasn't been saved to your workspace profile. [1]
- The Fix: Open the PDF where your custom column lists are working perfectly.
- Highlight your custom column and click Save to Profile.
- Go to Revu > Profiles > Save Profile. This forces Bluebeam Max to carry those suggestions over to every new document you open. [1, 2]
When you check Manage Columns, is this specific column currently formatted as a Text column or a Choice column? Knowing this will pinpoint the exact menu you need to alter. [1]
8 sites
Show allYou said: if i change it to choice it only allows me to do drop down. i can't enter text into itTo fix this, you need to unlock the text box capability inside the Choice menu by checking a specific configuration box. [1]When a column is set to "Choice," Bluebeam hides the flashing text cursor by default until you grant the column permission to accept free-form text. [1]How to Unlock Text Typing on a Choice Column
- Click on the Custom Columns tab.
- Select your Choice column and click Modify (or double-click it).
- Look at the bottom of that window. Click on the Format button (or look directly under the options area, depending on your exact sub-version layout).
- Check the box that says "Allow Custom Text".
- Click OK and then OK again to close out the menus. [1, 2]
