It would be real nice to have a toolbox where it shows a list of dimension names that you could just click on. For example: lets say your doing a wall base take-off on a large floor plan that incorporates several different types of wall base. If I could just click Base WB-1, do a dimension, then click Base WB-4 and do a dimension, then WB-5 and so on it would be quick and a huge time saver. Currently, you have to go to the drop down, sort through 100 previously used dimension items (also of previous projects), hopefully click on the right one and it is tedious as heck.
If it was along the same vein as the toolbox, that would be fantastic. You could add what dimension properties you want to use (along with a name) just for that project, click and go! It would be quick and extremely useful.
