sometimes i need to copy the name of the file i am currently working in. Rather than go into file explorer and do it from there, it would be nice to be able to do it straight from Revu.
Not exactly what you're looking for, but if you right-click on the drawing tab (or on the filename in the Recents list), you can Copy Path. Depending on how you're using it, this might be worth it even if you need to delete the rest of the file path. (Agreed that it could be useful to have Copy Filename as an option on the context menus.)
