OCR has not worked for over a month. is there a fix coming out? I have been getting this error:
I just tested mine and haven't had any issues. What version of Revu are you using? Does it occur with all documents you have tried?
We just got 21.10 installed and mine does not work.
It gets to 49% and then this:
Same here. Ran it on a 300+ page spec. No issues. Revu 21.3
This advice from Bluebeam support resolved the issue for one of our users: Thank you for contacting support and for sending the logs. From the logs, it looks like Revu is launching the OCR module correctly and then it creates a temporary file in the user’s temp folder that it uses to store some information that it will later use to update the original pdf (example: %localappdata%\Temp\tmpXXXX.tmp.xml), then Revu tries to open the temp file, but fails to do so. Because the temp file cannot be opened at that stage, it stops and shows the error message. The cause is usually that antivirus software in use on the computer is blocking Revu from accessing the temp file or is blocking the Bluebeam OCR module from running properly. To move this forward, could your IT team please run the following checks on an affected computer:
2. Check for security or AV interference
