Prompt Text
In the active PDF open in Bluebeam Revu, retrieve all markups and filter to only those where [FIELD] matches [VALUE]. Update the status of every markup in that filtered set to [NEW STATUS]. Once complete, confirm how many markups were updated and list them by page number, showing each markup's subject, type, author, and previous status before the change.
Filter field options: Author, Subject, Page Label, Markup Type, Color, or any other available markup property.
Expected Output
A confirmation message showing the total count of markups updated, followed by a page-by-page list of each affected markup with its subject, type, author, and prior status. All matched markups will reflect the new status in Bluebeam Revu.
Pro tips:
- Match field values exactly — the value you enter must match what appears in Bluebeam's Markups List. Check the list first if you're unsure of exact spelling, capitalization, or spacing.
- Stack filters for precision — narrow the scope by combining criteria: "...where Author is [NAME] and Subject contains [KEYWORD]..." to avoid updating markups you didn't intend to touch.
- Confirm your status model — substitute the exact status label your project uses (e.g. "Accepted," "Rejected," "For Record"). If no status model is assigned to the document, ask Claude to check before running.
Disclaimer: AI-generated results may vary based on individual user context, prior interactions, and stored memory within connected AI systems. Always review outputs for accuracy and suitability before using them in any professional or compliance-related workflow.
