When I create a hyperlink from one split window to another, the image shifts up every time. This makes it so I don't click on the correct place the first time.
the bar that shows up at the top that says "highlight text, choose two points, or drag causes the drawing to be redrawn slightly smaller. If you just make that overlay on top of the image instead and not shift the image to make it smaller to accommodate the bar, this issue would go away.
