We have the need to be able to select counted items from the drawing area and to be able to dynamically represent the count and detail in the markup list which will result in a circuited layouts within a set of parameters. Similar to a polyline count instead of the current method which we use which revolves around drawing boxes in 'Spaces'.
EG: as the (circuit) line crosses the symbols it creates a running total in the markup list based on the parameters of the count/items it encounters. This can then be filtered and worked with in the samne way as any column in the markup list.
