Default Callout Document Width is 1.75". I always waste time manually reducing the width to fit the text entered so that the right margin matches the left margin. It would be better if the left and right margins are set and the callout box adjust the size to fit the text.
Good news @kkinney - this is already a feature. Check out the "Preferences" settings:
Check the "Autosize Text Box and Callout Markups" check box and your boxes will autosize!
Alternatively when you create new text box or callout you can use the "Alt-Z" keystroke to autosize the active textbox.
Hope this helps! 😎
