After the recent update, my search function does not work any more. I have tried my files including the ones I have successfully searched words in before the update. Is this a bug? How can it be fixed?
If you have the search menu but it's not finding results - take a careful look at each search option and see if you have settings selected that are problematic. You may find an option that is on/off that you need changed in order to produce results.
Check to ensure that you're logged in to the correct version. Go up to your login at the top right and click on it, it should drop down and say which version of Revu you're subscribed to. If for some reason it's on "unpaid collaborator" you won't see the search function. Try logging out and logging back in, that seems to be the most common fix.
Thank you Gebelein, that fixed my problem. Apparently I have to select "search pages". Maybe in the previous version that box was selected by default.
Thank you Jason for the help. It was not the reason causing my issue but i will bear in mind when i debug next time.
