Please add an option to open bookmark links in separate window. This will allow people reviewing drawings, reports, etc to open up a reference link without losing their place in the pdf they are working on.
This is a great suggestion @Josh Gebelein!
Could you split screen and then click on a bookmark link? That way the original screen stays put and the split side jumps to the bookmark. Then you could drag the split side to another window if you wanted.
Yes, but that's extremely slow and much extra work when reviewing a large drawing set.
Actually, I just learned this IS possible! Click-hold-drag where you want it. I'm able to drag it to my second screen and expand to the whole screen. Not sure which version this came out in. I'm running 21.9
