When using the file access feature, there is an wide drop-down box for file types (PDF, Documents, or all types) the and left and right arrow before reaching the key elements: up one level, create new folder, pin folder. Is there any way BB can reorganize this header so the first item on the left is up one level? It seems I always need to open the panel wide enough to navigate to another document in a folder up a level or two. I'm always having to slide the panel wide then back to do work. It seems most people are consistent with the file types they want to see so if needing to change that, they can move the panel.
