Can I set (within my preferences) the units to be meters ? When I calibrate for dimensions etc, it always assumes mm's and not m's. I would like my default to be m's
When calibrating your drawings, ensure you select the correct units. Once you use your measurement tools, go to the Measurement Panel and set the units to be correct for each type of measurement. Then right-click on the markup and Set as Default. This way, it will be your default units going forward.
Thank you. This leaves me with the correct units set for when apply a measurement tool next. But I am wondering if I can set a default in the calibration area as well, this is where it keeps going back to mm ion me (vs m)
