How do i change the icons when i select count measurement checked after completing visual search? it only has the default icons and not option to add from my toolbox.
Are those icons defined as "Count" icons? RIght click on one and choose "create count" then you should see it below the default options when you want to create a count from a search.
You'll also want to update the subject of the count so it reflects what it is you're actually counting after you do the "create count" right click step.
The count option can also show you count defined symbols from your tool chest. If you want to apply a variety of different counts. Create those and save them into a tool set in the tool chest. That way you can select the one you want for each count.
How do I change the icons shown under "apply count measure to chest", or add those from my tool chest?
your Saved Count tools should be showing in a popup menu that will appear when you hover over " Apply Count Measurement to Checked"
If you're not getting that menu you have a bug and you should report it.
Maybe thats my problem? I did not save any count tools, it only displays the defaults. Is there an option to save count tools somewhere? I have a tool chest with a fair amount of icons.
Well I see now how to populate them into the tool chest and now they are visible in the search option.
I do not see where to update the subject name to match the icon used. There is no option when right clicking it in toolbox or the search option.
