The Prompt Text
Provide a narrative of the changes found using the overlay drawing function in the active PDF in Revu. The original drawings are in red and the revised drawing is in green. Black font indicates no change.
Expected Output
Output Format: Text Summary
Sample Output: Change Narrative for 1st Floor Plan - South
Room Number Changes: The most significant changes involve room renumbering in the upper right quadrant of the plan. Three rooms have been renumbered:
- Room 145C (originally room 138 in red) - revised room number shown in green
- Room 145B (originally unlabeled or different number) - new designation in green
- Room 146C, 146B, and 146A (originally rooms 140, 142, and 144 respectively) - complete renumbering sequence revised in green
Wall Type Modification: A wall type designation has been changed from "G2" to "G1" in the center-left portion of the plan near the stair area. This represents a change in the wall construction specification.
Dimensional Changes: Several dimensional modifications were made in the lower left area of the plan:
- A dimension string was revised from "6' - 11"" to "10' - 1" 9' - 10 1/2" 6' - 11"" - breaking one dimension into three segments for greater clarity
- Interior room dimensions were adjusted, changing from "7' - 7 1/2" 1' - 8"" to "3' - 5 1/2"", "11' - 4"", "10' - 8"", and "11' - 2 1/2"" - indicating a reconfiguration of interior partition layout
- Additional dimensional string changed from a single dimension to "5' - 6" 5' - 6" 5' - 2"" - subdividing the space
- A dimension was added showing "4' - 11"" and "5' - 3"" in green where previously different dimensions existed
Drawing Timestamp: The drawing timestamp in the title block was updated from "8/18/2016 5:39:49 PM" (shown in red) to "8/19/2016 11:22:48 AM" (shown in green), indicating this revision was completed the following day.
Elements Unchanged (Black): The majority of the drawing remains unchanged, including all general notes, grid lines, door and window locations, major room layouts, the title block information, and most dimensional strings throughout the plan.
These changes appear to represent design refinements focusing on room identification standardization and spatial dimension clarification in specific areas while maintaining the overall building layout and design intent.
Disclaimer: AI-generated results may vary based on individual user context, prior interactions, and stored memory within connected AI systems. Always review outputs for accuracy and suitability before using them in any professional or compliance-related workflow. This prompt's results are based on text changes within the drawings only, as Claude works entirely through MCP text-based tools.
