I created a formula column to calculate weight from an area measurement. In the "Label" field, I entered «Weight»# (where "Weight" is the name of my column). I clicked the "Set as default" button in the properties toolbar. When I create the first area, the weight is calculated correctly. When I create subsequent area measurements, the text from the first is inserted into the label, not the formula. for example, "1000#" instead of "«Weight»#". If I click the "Area Measurement" button between each measurement, it works fine. If I create a tool in my tool chest, it works fine for multiple areas. It's only when I use the "Create Area Measurement" button and the "Reuse tools" setting to create multiple areas that it fails.
I have "Dynamically Set as Default Properties" turned off in settings, and "Reuse Tools" turned on in settings.
