New to bluebeam, best way to locate stamp in a pre-determined location on a sheet?
If you are looking to apply the stamp to multiple sheets I think your best bet is the "Batch → Apply Stamp" sequence @Mike Brown. I haven't used it much myself, but that's where I would start if I needed to.
Hope this helps. 😎
Am I understanding your question as that you want to place the stamp in precise coordinates on your sheet?
@Mike Brown, A simple way to add a stamp to many pages is to place it on one page, size it, and put it where you want it. Then right click and choose Apply to Pages. That will place the same stamp on all pages you pick in the same spot and size.
the best way to do this would be to create a Script (Macro) You'll want to search in the Help Menu for Scrip Editor, and then navigate to where it says Stamp. From there you can write your Macro to place your Stamp.
Take a look at Batch/Apply Stamp……
