Currently I add each open file to an open session by "right click - Add to open Studio Session". Is there a way to batch this process? This would save me a lot of time.
You can upload a Whole Folder. Just make sure it has everything you need and that the naming conventions are set up the way you want them to be. As far as a Script, I bet that's possible but "Upload Folder" is already an option.
Good luck and Happy Bluebeaming!
I can add files to an open studio session with these 2 options. Under the documents tab I can select multiple files, except I often have my files in my folder that I don't want to add and the file names can be confusing. I want an "add all open files to studio session option"
Ahhhhh, Ok.
Below I created a new project "Test Test!" which allows the user to create a New Folder, Upload Files, or Upload Folder.
Or if you have the files open that you want to use, there is an option to add Open Files if you right click in the blank space on the screen.
I sugest that you make sure the file / files are unlocked and your Bookmarks and Page Lables are all set up before you migrate them in whatever wway you end up going.
Hope this help.
Cheers! and Happy Bluebeaming!
