I would like to know how could I clip a snapshot of a plan and drop it on a sheet with an elevation, then rotate the plan 180 to compare to the elevation?
@Lee Pellegrin, You can use the Screenshot tool (G) on the first plan, and paste it (CTRL+V) into the elevation sheet. Keep in mind when you rotate the sheet, the screenshot will rotate with it (so you might need to rotate in on its own) .
Hope this helps!
Yes, pasted snapshot can be rotated and also flipped horizontally or vertically.
