Add the ability to rotate a line, when selecting a line there should be a rotate grab point - same as is provided for a polyline.
Thank you @Josh Gebelein for pointing this out . I checked and you’re right, a Line does not have a rotate grab point like a Polyline does. I’m not sure why that’s the case, but hopefully it’s an easy fix that can be added in the next update.
I am amazed that managers or software people can't see that feature is missing when they implement the line object. Why in the hell would nobody think that a line never needs to be rotated? These kinds of oversights are frigging amazing. How could they miss such a feature?
Yup v strange they wouldn't implement that. However, I've just started using the Polyline tool to draw a straight line between two points and then using properties to rotate e.g. 90° etc.
