Can the rectangle sketch to scale be output as an actual rectangle instead of a polygon? or make two separate, i.e. "Polygon Sketch to Scale"
Created an account to say the exact same thing. And there is already a separate polygon sketch to scale so there is no reason for it to be this way
there is a Sketch to Scale tool for both a rectangle and polyline. Not sure what the problem is.
Then allow me to elaborate since you're missing the point. The rectangle to scale then becomes a polygon shape, where each control point can be adjusted. I would like the rectangle to remain a rectangle so if you were to drag a corner to enlarge the size, it does so proportionately like a rectangle markup, compared to a polygon markup that allows each individual control point to be adjusted.
Adjust using the blue squares instead of the yellow dots. Bear in mind that you can't stretch along the x or y axis, you can only make it proportionally larger or smaller.
Right, which can work as a work around, but I don't see why we can't have the control points do this just like a rectangle markup (instead of a polygon). You drag a control point and it would increase that point wherever you drag it (for instance, to snap to content on the page) and keep an updated area measurement, rather than guessing the size by dragging the blue squares until you approximate the enlarged or reduced area (since it cannot snap to content). It is a miniscule change, but would be a nice one to have.
