Often it is necessary to remove a number of control points from a markup. Currently I'm aware of two ways of doing this:
- Select a point, right click and select "delete control point" then repeat for every point that need to be removed.
- Select the "Subtract Control Point" button and click on each point to be removed.
Suggested addition would be to add the ability to select multiple control points - perhaps with a tool similar to the lasso tool and then delete the selected group of markups.
This would be very useful for modifying large area measurements or for eliminating large numbers of points from a polyline or perimeter measurement that you don't want to split into smaller pieces.
