Had some associates do their Bluebeam update and now they are not able to print their pdf document to a printer. Any advice?
We encountered a similar issue recently where several users were unable to print PDFs. It was resolved by enabling Bluebeam within their Startup Apps settings.
21.7 has a few major bugs. Uninstall & then download / install 21.6. This is the link I was given.
https://support.bluebeam.com/download-archive.html
I've not heard of this issue but I've just had someone tell me that since doing the update, it takes an extremely long time for drawings to open in the first place - 30 seconds or more whereas it used to be fairly instant.
I can't install 21.7 at all. I tried the update, I tried downloading and installing the app. After 90 minutes there is no progress.
Hi,
Could I ask exactly what happens when trying to print to this printer? Do any error messages come up on the screen, for example?
Furthermore, does the same thing happen when using an alternate PDF viewer, such as Adobe or Microsoft Edge?
Was there a fix for this? I am having the same issue.
