Hi all.
Anyone else having a problem since the latest update, where you go to change a line size & it jumps up to highlight?
You are not alone @Andrew Samsworth! There are a number of post with similar issues:
The Bluebeam Team has acknowledged the issue. I have to imagine that it is impacting 10s of thousands of users. Hopefully they will issue an update shortly that will correct this!
jalbrightSep 10, 2025
When selecting a markup to use such as one that measures area for carpet, while in the process of using the markup tool, the wall lines are totally obliterated by a solid line that is impossible to see through no matter what the opacity setting is of the line. This leaves the markup a matter of guesswork as to where the room corners should anchor to. After completion of the markup, it becomes necessary to make a second trip to move the anchor corners to their appropriate place. This was not a problem with the last update to Revu but only began after upgrading to the latest build which is V21.7.12289.
View PostView Post
i think i am having the same issue as you, when i measure a line it has a thick line and you can't click on the correct point to measure?
