After my laptop was replaced and I reinstalled all engineering apps, including Bluebeam. However, the Projectwise plug in is completely missing. Of course, not having plug in, I can't configure my datasources. All I have is sharepoint as document management system in preferences which is totally useless for me as for many engineers, and I can't switch to Projectwise which is standard issue Common Data Environment for engineers. We always run sessions from Projectwise/ Projectwise Web, building sessions directly from the deliverables. The selector is not working, sharepoint is greyed out and can't be removed. Also, Projectwise is not listed under Administrator at all which tells me it is not installed. Since Bluebeam is not handling Projectwise 2024 yet, I keep the lower version 2023 to allo integration.
I can't upload images showing dialogue boxes described above, it says 'permission problems'
How can i fix Projectwise integration and load up Projectwise plug-in?
