Instead of having grouped security settings, you should be able to choose which security settings you want to implement specifically. Such as, instead of "Insert Delete Rotate Pages", there are checkboxes for Insert, Delete, Rotate. I would like to be able to allow extracting (the "Allow Extracting Content for Accessibility" checkbox doesn't seem to work), and printing to PDF, but keeping the security of not allowing markups of any kind. You can't print to PDF, however you can export to PDF/A and print to PDF from there. What is the difference? Either way, you can make "Print to PDF" a standalone option.
