Where do I change the current , at decimals, to a .
Go to preferences and then Import / Export as follows: -
When I scale a document, I'm not able to insert a . separating decimals.
Thank you for all the answers: new computer, I;ll be sorted soon
Separating decimals? I don't understand.
