Please add an option when performing Save As… to exclude all markups.
In the print dialog box, there is an option to Print: Document & Markup, Document Only, and Markups Only.
Select Document Only and print this to a PDF and voila.
Printing to pdf fundamentally alters the pdf file. Looking for a quick way to keep the base file in it's original format with comments removed.
there is one solution. please check if it fits in your requirement.may be you already know.
If your markups are done and no further markups gonna add later .just select all markups delete them & then go for save as option. this will create separate new file without markups and then just by clicking ctrl+z you can bring back all markups in native file.
Does not work for files in session.
Oh… this is in session, an important detail.
Best advice, limited by the situation here… THINK AHEAD…
Correct, markups cannot be removed from sessions except for ones you created. The whole purpose of a session being that the pdf is in the state of approval at the end of the session. May be a problem for the request if they are maintaining that line of thought.
Not many options when printing w/o markups doesn't fit your workflow. The simple answer is Right click the file name tab in the session, Save As for a local copy. Open that one up, remove the markups and save again.
