Hi,
Which is the latest version of the Bluebeam software? 21.0.50?
Thank you!
If you navigate to
Bluebeam Download Center - Revu and Cloud - Bluebeam
The download there is for Bluebeam Revu 21.6.1.
I have lost track of the issues reported re version 21.6.0. We are using 21.5 across all end-users.
wow 21.6.1 was supposed to come through.
2
Doug,
Sorry, I didn't understand your reply, but thanks for your time……
Thanks a lot, Michael!
Doug McLean:
Thanks a lot!
Hi All, I am trying to add revised sheets to my Set(.bex) using Batch Slip Sheet. The problem is when I hit the Match Pages button I am receiving error messages (See images below). I believe the problem is coming from BB including previously revised sheets in the Current Files column of the Match Pages window. Am I doing…
When I zoom on one tab the other tab is adjusted as well. I am using my mouse scroll to do this. I also just updated to the latest version of Bluebeam. Is there a fix for this? Is anyone else experiencing this?
When taking off quantities in lengths i prefer to use m rather than mm. Is there a way to set this as the default for all my take offs
Hallo, ich bräuchte Hilfe bzgl. der Polygonlängen - Messung in Revu 21. Ich habe eine automatisierte Baugrubenkalkulation in Excel aufgestellt, in der ich anhand der Polygonfläche des Gebäudegrundrisses die Volumina und Flächen ermittelt bekomme. Aktuell tippe ich die Koordinaten in Excel händisch ein, welche ich von PDF…
Hi everyone, I’m running into an issue on a new laptop and I’m wondering if anyone else has experienced this. I have an active Bluebeam Basics subscription, but when I sign into Bluebeam on my new laptop, I get a message saying my free trial has expired and that I need to upgrade to keep using the software. The same…
Hello! I am trying to get curves to draw when using the polyline and polygon markup tools and they show up like they are going to be drawn as a curve but then when I click along they 'revert' as a straight line. To clarify, when using either markup tool, I hold 'Ctrl' then click and drag to create the curve/arc that I want…
Several Municipalities are requesting the PDF's be Unlocked so they can mark-up and add their stamps. Much to Engineers sealed drawings, they do not want them unlocked. I tried scanning and sending them, but they are still locked. Can a blank mark-up layer be added before or after password protecting the drawing?
Hi everyone, I’m working with a new license that doesn’t seem to work. Everything is greyed out, and I can’t select any functions in the different documents. Is there something I forgot to activate or similar? I’ve paid for the “Core” version.
Hi Everyone, I have been back and forth all morning trying to reset my scale sizing. it is showing my measurements in inches and ft but I need them in m2. When I then go to remeasure it just goes back to the original inches and ft. Could some one please tell me how to reset this fully as i have never seen this before.
I'm trying to edit an interactive stamp I've created to have a dropdown field for our cost types, but I can't get the javascript code to work correctly and every time I try I'm losing the dialog box. I've linked Test Stamp 1 (the fields all fill out the way I want, but the Cost Type isn't a dropdown) but I know there's a…
