I pick Edit > PDF Content > Erase Content
Won't easer the W
Pick more then the W its gone.
It appears that some context is missing from this post.
Sometimes with the eraser tool you will need to select a wider area than the visible graphic in order to capture the data to be removed. Zooming in can help, but it can be tricky. Just the way the pdf data is managed I guess.
There is a black line that appears when converting from PDF to TIFF. It normally blacks out the title block but have had it black out parts of drawings recently. Is there any way to prevent this black line?
This might be a really obvious one but I can't seem to figure out the best way to do this: I frequently mark up drawing sets for estimates wherein there are multiple pass-through trades under my scope. What I want to do is to be able to do takeoffs for multiple trades, giving them each their own layer that represents them,…
Need help with my cursor and measuring tools. My cursor will only go in a straight line in the measuring tool I am unable to follow a radius or use the measuring tool correctly, it will not follow the cursor but only go in straight lines.
Last night, our Admin team nearly lost their minds. While converting 92 Word documents to PDF, they discovered that the new PDFs were displaying the old versions of the Word documents. Any ideas what caused this and how to prevent or correct the problem if it happens again? They converted perfectly this morning.
What’s the Best Way to Measure LF on a Curved Wall?
Hi. Is anyone experiencing their toolsets randomly removing the first item in the list and replacing it with another? For example, I can open a set and the first one in the list should be say a 3-pole plug, followed by a 4-pole, 5-pole etc. but for some reason the 3-pole plug has been replaced by something random from a…
I have noticed when saving a file as PDF from Word the are sometime several bookmarks listed as "1". Bookmarks are created using Word headers, but there are never any headers named "1". Does anyone know why this happens and how to prevent it?
Is there a way to add together measurements between multiple pages? Say I markup a ton of items as MTL-2 over many pages; is there a way to add them all together? Like the legend below but for all pages with MTL-2
Just did the update this morning. Everything went well except I no longer have the Revu icon. It is just looks like a piece of paper with the right, top corner bent over. Is this the new icon or did something not load correctly?
I did not see this before but lately yes - when you click File/Email on any open file, the email window opening up will have the file attached but the actual file name will have [1] added to the name looking like ***[1].pdf while the subject line shows the original file name. How can I stop this so the file name does not…
