Hello,
It would be great to not have to use a work-around or other pdf viewer to see the background images created with Rapid Plan.  It should be noted that the images render fine in Bluebeam, but do not if I fade the images in Rapid Plan before exporting them to pdf.  I am often checking the look of my product from Rapid Plan by exporting it to pdf.  Having to print it again to pdf just to see the final product is extra steps and adds up over time.  I could see having to do the extra steps 50 times or more for each project.  After putting a few hours into communication with Bluebeam and Rapid Plan to sort out the problem it was suggested that I make a request here.  I also noticed that when I created these pdfs in March of this year that this was not an issue.  Thank you for the consideration.
