Since it looks like there is no way to unflatten a form field I am wondering if there is a way to lock one. So far I am not able to get it to work.
Thanks
There are several options, Lock will keep it in place and the properties will be locked but still able to be modified. Read only will keep people from modifying it. Visibility settings can hide it. Putting it on a layer and disabling, or even setting it to be off by default is a way to keep it out of the way as well. The last two options are pretty similar, in that the fields still exist, but you just can't see them unless you go into form selection mode. Personally I like the layers because I can use JavaScript to turn the layers on and off with buttons.
