There should be a way to add layers in a pdf on blue beam studio
to have to set them all up sheet by sheet then upload them is very time consuming each time a new sheet is added or if someone else adds sheet
Hi fellow Bluebeam User, To be clear, there are two parts to Studio - Projects and Sessions. I believe that you are referring to Sessions. Part of the rules for Studio Session is that the PDF cant be edited once its in the Session, having more flexibility is a good feature request, but what can you do today? Have you used the Batch functions that are in the Complete version? There is a Batch Script that will allow you to add Layers to as many drawings as you need in preparation to load up into a Studio Session. The way you do this is to create a Script that imports a "Master PDF" that contains ALL the Layers that you require, into the PDFs that you want to load up into Studio Session, then delete the Master PDF, leaving your Layers behind.Here is the Script: InsertPages(0,"{add in your Master PDF location here}\Master_PDF.pdf", false, false, false, true, false) PageDelete(1) The one true value is (please check) the option (boolean) to import the Master PDFs Layers into your PDFs that are to be uploaded into Studio Sessions. Let me know how you go.
I add the layers prior, i appreciate the input I wanted to see if there was ever a way to add layers once in a studio session
Shanoc, the extreme lockdown of options in bluebeam sessions is a feature great for collaborating with outsiders to your organization, but users have wanted for years to be able to reduce those restrictions and collaborate internally on one PDF, with the ability to edit others markups and you know, use the program for all its features.
hello, thank you for your response It shows my subscription is CORE for Revu 21 Version 21.6 x64 Core This means im not able to do the script, I have been creating the layers each time i have to upload to studio I am not sure how to make a template for just the layers and import them easier then re created them each time
Please make this a thing that can be changed in permissions. I would like to implement this into our workflow, but in it's current state it will require too many work arounds
