We have AGTEK users that provide us with material takeoffs, dirt work quantities etc. Is anyone here importing AGTEK material takeoff markups into Bluebeam? Thank you!
Here is what google AI thinks the process is…
if you do an Export markups it saves that file as a .bax file, so I would imagine that would need to be the file format if you wanted to import any markups. Somehow, I don't see Batch Slip Sheet working too well.
I do a lot of automation in this space so I'd be interested in looking into it if you'll show me the available export workflows. I'm betting the data is available there somewhere.
