Hi All! Thinking of what my first post will be… here's a question.
What is the timeframe of the next major release of Bluebeam? (Bluebeam 2024, Bluebeam 2025).
Currently the latest Major release is Revu Bluebeam 21 still?
Hi Tom! We're continually developing and improving Revu, and we're releasing updates on a quarterly schedule. Revu 21 is the major version that's part of our Bluebeam Plans, and we will continue releasing updates for it every 3 months roughly. Each update will introduce new features, include enhancements to existing features, and provide bug fixes for issues affecting our users. I hope that helps. Please let us know if you have any other questions or thoughts to share!
