I know this is a little lengthy, but I tried to make it totally clear and understandable. I hope I succeeded.
When you open "Manage Columns" there are two tabs, "Display Order" & "Custom Columns". Once I import my custom columns, I want to setup the order in the "Display Order" tab. This procedure sets the order the columns appear in the Markup window, below the NAVIGATION BAR area. I do this so that when I generate a CSV summary, to prepare to copy the data into my excel pricing sheet, the columns will be printed in that same order on the CSV report as they are in the Markup window.
I take the time to set the Display Order the way I want to and all is well while I am working that session. When I shut Revu down and restart later, the Display Order tab has reverted back to how it was before I changed it.
My question is. Is there a way to save this new tab arrangement so it becomes the default tab? Or at least can be reloaded or imported?
Thank you so much, alan
