How do I default certain colors and degrees of shading? For example, if I need a text box it defaults to red at 100% also the text color. When I need a text box, I need it yellow at 40% and the text black.
Set a text box the way you want. Then select it and click on "Set as Default" at the bottom of your markup settings. You may have to scroll down to see it. Let us know if that doesn't work or is not what you wanted.
Awesome! Thank you!!
No problem. However, it appears you accepted your comment as the accepted answer instead of mine. Usually I wouldn't care but when I checked for an update, it hid my answer because it had defaulted to display "accepted answers". That "tab" is not obvious so someone new would be pretty confused that you praised yourself 😁
There was an error rendering this rich post.
Is there any consideration for Bluebeam to have a feature to reassign markups? I know it is simple to change the properties to a different markup but then you get into the game of changing the color and everything else. Wouldn't it be simplified if you could just reassign it to a takeoff, you've already utilized or…
Recently, I've been experiencing and issue in that when I use my hotkeys for the typewriter or text box, they don't work. I used to be able to then go click the icon on the bar and I'd then be able to drop a textbox or get the typewriter cursor to appear, but now that doesn't work either. I just tried uninstalling and…
I am not able to choose different colors for my layers when I am overlaying more than 8 layers together. All I am seeing is the graded color palatte in revu v21 rather than the default one where we can customize the colors based on the RGB values. Has anyone faced this issue before? Is there any workaround for this to…
How do I ensure my session allows for plan review markups? I cannot sort out how to enable one of my sessions to have both the review and plan review tab.
Small Biz and we have BB Revu 20 still in our conference rooms because it does not require sign-in. I tried putting Revu 21 in one conference room and had it signed in with it's own account, but then there were server side issues and then login was required again. Users were confused and entered their own login for…
Some of the BB marked up PDFs I receive have shading and "draw order" out of whack to the point that I cannot read what's below the block. All of the items should come in like the "12' APPLES" unit, in orange. Any thoughts? The preferred "Order" would be with the shading at the base level and the pasted fixture block above.
we have installed the software and tried to login with "name_example.com" Account using "Bluebeam Australia Region"., But it is not allowing to login. Showing the error like below snip. But., we tried to login with "Bluebeam United States Region" and it allowed login, but the Plan is showing as "unassigned" like below…
Hello!! I have been using Bluebeam for a decent while, and anything I have trouble with I can usually sort out on my own, but I am stumped. We have a set of plans, all of which are images with a peach-coloured background. To save on ink, I need to change them to grayscale, ideally. Please see the attached screenshot. It…
On Windows, some PDF previews appear in my folders sidebar while others do not. It seems like the ones I created show a preview, but the externally generated ones don't. Is there a setting I can change to make all PDFs show a preview?
