Hi,
I have experienced several times an odd issue today: As I flattened, then un-flattened my mark-ups on a document, these were duplicated.
Has anyone experienced this before, and does anyone know a workaround?
Hi @Eric Sturel - Thank you for posting in Bluebeam Community! What you’re describing sounds like a scenario for our technical support team. Please complete this form and they’ll be more than happy to assist you! https://support.bluebeam.com/en-us/contact.html
