Good morning, If anyone has Spectacle Blinds and a Spacer tools, could you please share them with me? I need to mark up P&IDs in Bluebeam for the Oil and Gas industry. Thank you.
Are you looking for a tool set symbol or illustration? I'm surprised it's not already included in the Bluebeam P&ID Review Valves tool set. Making your own is actually pretty easy. https://lizlarsen.me/bluebeamblog/2021/03/16/your-personal-toolchest/
