I am a flooring contractor and I am trying to takeoff rooms using 6'7" sheet goods. Is there a way to measure the area and autofill the seams every 6'7"?
Are you just looking for a floor pattern or a quantity count?
Would the seams be staggered or aligned?
I am using broadloom 6'7" sheet goods and want to show a seams. They would run parallel
Ah, 6'-7" wide roll. I was thinking sheets like plywood (my bad). If you just want a pattern, you can make your own. You can even import from AutoCAD. https://support.bluebeam.com/online-help/revu2017/Content/RevuHelp/D--Unsorted/Hatch-Patterns--V.htm
