I want to fill in a wall with an archway …. Also want to colour this in ( highlite it ), then measure out panels to if there area with these panels
@tony ferruccio
Do you have access to a tool call Dynamic Fill? End of your measurement toolbar. This tool can be used to "flood" an area and then create different items based off that flooded area. Could use the area measurement to get the values you need. Dynamic fill is part of Revu Complete. There's more to it than the very basic description here, but it can be a great way to work with shapes that are more organic in design.
Thanks Ken
All sorted upgrading the Program as we speak
Appreciate you feed back
