When opening a document FROM SharePoint using the 'Open in Revu' menu option, please make the 'Save As' path save to the SAME location it was opened from. Same with opening a PDF in SharePoint via the DMS connection. When you choose Save As, it should save back to the same location it was opened from. It's very inefficient to browse and navigate back to the original location the file was opened from. The File / Open in DMS is also dreadfully slow. Thank you.
