When adding a markup measurement, the label and quantity automatically copies to the comment field. Is there a way to disable or have an option (Copy or Do Not Copy) as a preference for this feature.
There is a difference in the comments function between the dimension tool:
and the length tool:
You can custom edit the text (comments) with the dimension tool.
The Length tool, assuming what you are posting about, is an automatic text/comment based on set scale.
