Hi,
I wanted to know if there could be a way to import a list (column) from Excel into Bluebeam turning each item into an individual markup (callout box). For example, in this attached file, I would like everything under "Permanent Label ID" (column J) imported into a Bluebeam drawing (floorplan) I am marking up. The number of Label IDs could range up into the thousands, and sometimes there are more texts in each Label ID, which can be very tedious to type in.
